on 01-09-2022 09:47
Transferred number from another provider. AppleID shows my number but iMessage and FaceTime still show the number of the sim
on 01-09-2022 09:54
Hi there Fernie136,
Thanks for your post and welcome to the community.
Just to clarify, has the number transferred through successfully?
Also you'll need to update the iMessage number to the correctly designed phone number through by going to;
- Settings
- Messages
- Then Send & Receive.
Let us know if that helps,
on 01-09-2022 10:14
The number has transferred ok. I can ring my iPhone but no texts are being received
I have tried send / receive countless times.
“an error occurred during activation”
on 01-09-2022 10:18
Thanks for the response,
Did you check the setting above that was advised?
If so does that also state the new number?
Regards,
on 01-09-2022 13:10
Yes I have checked. Showing wrong number
on 01-09-2022 13:54
Thanks @Fernie136, if you access the Settings on your iPhone, you should then be able to manually update the phone number to the one you have ported over to us and this should then register for the iMessage and FaceTime applications.
A rebooting of the handset may be required.
Kindest regards,
David_Bn
on 01-09-2022 14:17
Also try switching off your phone, signing out of you Apple ID before starting your phone and signing in again.
on 01-09-2022 14:50
Won’t let me edit it. Tried that before posting. Reboot last night and phone switched off for at least 8 hours
on 01-09-2022 15:00
Thanks for coming back to us @Fernie136, can you please confirm what handset you're using and what software is currently installed on the handset?
Are there any software update currently due?
Kindest regards,
David_Bn
on 01-09-2022 15:13
iPhone XR. No software updates due
