bexylou02
  • 9
Message 1 of 32
iMessage & Facetime issues after switching to virgin
i switched from EE to Virgin this completed 4th Jan
however ever since this completed i have not been able to activate iMesage or Facetime on my iPhone 11
i need to find out if my contract is provisioned for iMessage & if my plan is able to send international messages- i’m not able to get through to customer services 🤦🏽‍♀️
David_Bn
  • 8.66K
  • 361
  • 669
Message 2 of 32
Re: iMessage & Facetime issues after switching to virgin
Thanks for your post on our Community Forums @bexylou02, and a very warm welcome to you!
Sorry to hear of the issues you've experienced with iMessage and Facetime on your iPhone 11.
Can you please advise me if you've ported a number in from EE to Virgin Mobile?
If so, you may need to update the phone number manually in the Settings on the handset.
The handset will detect the original number provided by Virgin Mobile, and will not take any porting request to Virgin Mobile into account
Do give this a try and let me know if this helps resolve the issues you're experiencing
Kindest regards,
David_Bn
bexylou02
  • 9
Message 3 of 32
I have been through all the setting numerous time and i’ve been on the phone with apple for hours on more than one occasion and everything is correct my number is my ported number from EE that’s come over to Virgin @David_Bn
David_Bn
  • 8.66K
  • 361
  • 669
Message 4 of 32
Does the handset or the applications require any software updates?
Can you advise me what Apple have advised you?
We wouldn't have the ability to disable or effect any use of applications on the handset and your contract would be provisioned to use the applications you refer to
Kindest regards,
David_Bn
bexylou02
  • 9
Message 5 of 32
everything is updated
Apple have told me to check those two items with you as from their side everything is set up correctly.
i have found threads from last year with many customers having the same issue as me when switching to you but i could not find a resolution- my iPhone is set up exactly the same as it was prior to me putting the virgin sim card in and my number porting
Travis_M
  • 3.91K
  • 140
  • 289
Message 6 of 32
Hi @bexylou02
Thanks for the reply!
The number wouldn't restrict you from sending iMessage or using FaceTime as the iPhone should automatically use your Apple ID if it cannot use your mobile number for whatever reason, so if FaceTime or iMessage isn't activating at all then this is certainly an Apple issue.
Can you advise what error message you get when trying to FaceTime someone?
Travis_M
bexylou02
  • 9
Message 7 of 32
the error stated activation unsuccessful
theg work perfectly fine with my email address it is my mobile number that it will not allow me to activate - i have spent numerous hours on the phone with apple and all settings are correct
i’m getting very annoyed now and regretting switching to yourselves as i’ve never had this much issue with other providers.
enlli
  • 9.52K
  • 1.43K
  • 2.74K
Message 8 of 32
There have been a couple of cases where the following has helped.
Sign out of your Apple ID
Switch off and Reboot the phone
Sign back in to your Apple ID
Travis_M
  • 3.91K
  • 140
  • 289
Message 9 of 32
If you could try the above from the very helpful @enlli - let us know how you get on.
If your normal calls and texts work then your mobile number has ported over correctly.
Travis_M
bexylou02
  • 9
Message 10 of 32
Yes that has worked !!!
3 days of going round and round in circles - i thank you very very much for your helpful workaround 😊
