Sign in
Sign out
on 12-08-2021 21:57
I'm trying to use my sim in a 3 WiFi mobile dongle. I have done factory reset. But sim not connecting to Internet. What am I doing wrong
Answered! Go to Answer
on 13-08-2021 11:35
on 13-08-2021 11:39
And if it isn't locked there is a good chance you will have to go into the configuration menu and update the APN settings
on 14-08-2021 11:49
Hi @bobp17,
Welcome to our Community Forums and thanks for posting.
Could it be that the mobile dongle is locked to the 3 network as suggested by @ashpole?
Drop us a message if you still need any help with this.
Found this answer helpful? Share it!
