kevin126
Message 1 of 7
Wifi calling and 4g calling not working
Both Wifi calling and 4g calling were working fine on my old device but unfortunately its now broken. I have been given my wifes old Pixel 4 xl but the options to turn on either service are missing with the Virgin sim. If i put my wifes o2 sim into the pixel then both options are there but gone with the Virgin sim. Any ideas ?
enlli
  • 9.81K
  • 1.45K
  • 2.82K
Message 2 of 7
Re: Wifi calling and 4g calling not working
What happens if you put the Vigin SIM in your wife's phone?
kevin126
Message 3 of 7
It works in my wifes phone as it did in my old phone
enlli
  • 9.81K
  • 1.45K
  • 2.82K
Message 4 of 7
Sounds like the Pixel 4 may not be compatible with Virgin
Unfortunately their list of compatable devices has not been updated in 9 months but it is not listed.
kevin126
Message 5 of 7
Thanks for that. I guess once the O2 move happens then it should work.
enlli
  • 9.81K
  • 1.45K
  • 2.82K
Message 6 of 7
I know for certain the Pixel 4 works on O2
Zoie_P
  • 5.28K
  • 218
  • 409
Message 7 of 7
Hi Kevin126,
Thank you for your post and welcome to our forums 🙂
I am sorry to hear you are having issues with your phone. As @enlli has advised this handset is not compatible, you can find more info here.
Zoie
