digginsa
Message 1 of 13
Wifi Calling issue
Hello,
Im having issues with wifi calling, if a number tries to call my mobile it shows 5-6 missed calls and cuts the number off, I have dialed my own number and see the number flash up on my device but does not connect or even go to my voicemail, if I switch wifi calling off everything works, I have tried my sim in a different phone and still the same issue.
Anyone else having problems?
stuartp22
  • 5
Message 2 of 13
Re: Wifi Calling issue
Yes I have exactly this same issue since a week or two ago. Only just tracked it down to WiFi calling which up until then has been working perfectly well
Sounds like another VM fault to fix so based on the thread about OTP texts not arriving I shan't good my breath lol.
Emma_C
  • 8.28K
  • 512
  • 559
Message 3 of 13
Hi Diggins and Stuartp22,
Very sorry that you're having some issues since using Wi-Fi calling, this is odd.
I'd also like to apologise for the delay in getting back in touch, we have been busier than usual.
Are you still having this issue at the moment?
Can you advise what handset you're using?
Emma_C - Forum Team
grsmith
  • 5
Message 4 of 13
Yes, same for me. I had 5 missed calls this morning. The person trying to contact me said they heard three beeps and the call disconnected. No diversion to voicemail. I’m on WiFi calling, using on iPhone Xs. I switched off WiFi, then reconnected and all was fine.
Emma_C
  • 8.28K
  • 512
  • 559
Message 5 of 13
Thanks.
If you’re having problems with dropped calls, calling not coming through or poor call quality when using WiFi Calling, it might be because you’re moving in and out of WiFi networks or there are a lot of devices trying to use the same WiFi connection.
In some places it might be that the signal is better than the Wi-Fi connection so will work once the Wi-Fi calling is switched off.
If you don’t see WiFi Call displayed on your device when you’re connected to WiFi, check that your device has WiFi and WiFi Calling switched on. If you can see WiFi Call displayed on your device, there might be a problem with the WiFi connection that your device is using.
If you’re using WiFi at home, make sure your device is in range of the WiFi hub, check your broadband connection and contact your broadband provider if you still have a problem.
If you’re not using your home WiFi, moving away from the hotspot your device is connected to will mean your connection will drop out. If there’s poor WiFi coverage where you are, switch off WiFi Calling until you’re in an area where the WiFi connection is stronger.
For further assistance please see here
Let us know if you need anything else.
Emma_C - Forum Team
digginsa
Message 6 of 13
Hello,
Yes still have the issue, I am using an iphone XS, when I see a call come in it shows as missed call sometimes a single call will show as missed call upto 6 if not more. sometimes the call does get through, but when it drops the call it just disconnects the user trying to call it acts like I hung-up he call, if I turn wifi calling off the problem goes, however the VirginMobile signal where I live is awful so I really need wifi calling.
Emma_C
  • 8.28K
  • 512
  • 559
Message 7 of 13
Thanks.
So is this when you're at home it's doing this or everywhere, as you would need a constant Wi-Fi connection for it to work.
Emma_C - Forum Team
digginsa
Message 8 of 13
Hello,
Sorry but I have a Unfi wireless network in my house and the Wifi signal is not an issue, my phone is right near an Access point and I still get this issue, this problem is not down to local customer equipment its on the virgin network side, it started happening for me when my virgin hub got a new public IP address having had the same one for almost  year, my Son is on 3 and wifi calling works fine, why I appreciate you trying to help please dont always jump to it must be the customer wifi that is the issue this need a deeper technical investigation.
enlli
  • 7.36K
  • 1.16K
  • 2.08K
Message 9 of 13
One big problem Virgin face with WiFi Calling is the inability to drop back to 4G if needed. Most other networks have voice over 4G. My Vodafone SIM will switch between the two seamlessly, as did one on 3
silverstreak_06
  • 5
Message 10 of 13
...and as a result the devices tend to power save, thus one of these is by turning off Wifi RF.  Once the call comes in, the phone wakes, and switches the Wifi on, thus the call dropping, although I would have thought it would have stuck to normal voice at this point?
Perhaps this is not the case, has anybody left a phone on charge, and it works as normal?
