WiFi calling. Possible on OnePlus 10t with Virgin??
baldswine
Hi, anyone had success? Is there a list of supported phones for this device. WiFi calling says enabled in phone settings, but trying to ascertain if working by going into flight mode then turning on WiFi only it appears not. Any ideas?
Thanks.
3 REPLIES 3
enlli
There is a list but it is dated May.
https://www.virginmedia.com/help/mobile/wifi-and-4g-calling
Hi, thanks for reply. Unfortunately no list visible on link posted. One that appears to be a link for a list is dead.
Apologies, found list. Sorry.
