WiFi Calling Not Working
bbunited
I just switched from EE to Virgin and it appears that my WiFi calling isnt working on my phone. I've read that it could take upto 24 hours?
4 REPLIES 4
bbunited
Ah does it need turning on from Virgins side? Can a Virgin team member help with this? 🙂
Joseph_B
Hey @bbunited,
Firstly welcome to the Community Forums and thanks for the post.
With regards to the WIFI calling activating, yes it can take up to 24 hours to fully activate. You can find out more information with regards to WIFI calling here.
Hope this helps. Joe
Ok thank you for the reply. So I don't have to have it enabled by Virgin? I just wait and it should automatically come on within 24 hours?:)
Hey @bbunited,
Thanks for getting back to us. Yes, as advised when you enable it yourself it can take up to 24 hours for it to fully activate, from then you will have WIFI calling enabled and don't need us to do anything.
Thanks. Joe
