@tillyandmo wrote:
If I make a normal phone call to another mobile while out and about will volte use my data.
No. In the future the majority of calls will be VoLTE. It is essential for calls on 5G and allows for calls to drop back to 4G when moving out of a 5G area. Also 3G will eventually be turned off.
I've been using VoLTE for over a year.
