on 08-04-2022 12:04
I tried to access voicemail but it asked for a pin straight away which I have never set therefore I have been locked out after trying to access it three times. I cannot ring 789 to speak to anyone and reset it as my phone is not allowing me to call, maybe because I am currently abroad? Is there a way to reset the pin online?
on 08-04-2022 16:15
Hi @RachelWelly
Welcome to the community!
Sorry to hear you're having issue with your voicemail at the moment. Please join me on private message so we can take a look at this further for you. You can see your private messages at the top of your screen in the envelope icon
on 08-04-2022 18:04
Hi RachelWelly,
Thanks for coming back to Carley via private message and passing data protection.
I have reset the voicemail pin for you now and you'll receive your new PIN by SMS. You will need to reset this after receiving the SMS, by calling your voicemail. The following points are guidelines for setting up a new PIN:
If you have any further issues, pop back to me here and we can go from there 🙂
