Skineggi
Voicemail problems
Hello,
Just carried out ios 14 upgrade on my iphone 6s and voicemail tells me every few minutes that I have a voicemail when there are none.I have tried power down, resetting network settings and calling voicemail all with no luck.
Any suggestions would be greatly received.
Roy.
Aaron2
  • 869
  • 98
  • 162
Well-informed
Re: Voicemail problems
Eugh, don't get me started on that issue, it's an iOS issue. Basically you need to go to voicemail then dial it, wait for the options then back out and then go to keypad, contacts then back to Voicemail until eventually it deletes, been happening with me since iOS 13, it's just iOS being dumb..
** I work for VirginMedia but all opinions posted here are my own.
Skineggi
Will try that !
Thank you Aaron2
