on 22-04-2023 17:26
Hi I’m currently abroad and am having the same problems as others in regards to a voicemail pin.
Please advise as to how to reset a pin I have never had!!
on 23-04-2023 09:24
Hi Bri4, thanks for the message and welcome to the forums.
I am sorry to hear that you have not been able to access the voicemail while abroad.
I will send you a private message so that this can be looked into further.
Please look out for the purple envelope.
Kind regards, Chris.
