MrsOverall
Voicemail pin
I seem to have an increasing number of voicemail messages but I can't access them now I'm in France. I have absolutely no memory of ever setting up a pin for this service.  Calling 7890 just leaves me holding for a suggested 45 minutes. No way!
Please help. It might be the ferry company cancelling my crossing!
enlli
  • 7.43K
  • 1.18K
  • 2.1K
Re: Voicemail pin
Until a member of the team gets here to set a temp pin (They will need your account details) can you not phone the ferry company? I'm sure I've phoned both Brittany Ferries and DFDS when in France on different occasions.
Melissa_F
  • 2.85K
  • 161
  • 230
Moderator
Moderator
Re: Voicemail pin
Hi MrsOverall,
Thanks for your post and welcome to the community.
Apologies that you're having problems accessing your voicemail due to a pin restriction.
Don't worry I can help you with that, so I'll pop you a private message now.
Melissa
