AnneKen
  • 6
Message 1 of 19
Voicemail pin reset
I can't access my voicemail, says pin not correct, but is the only one I've ever used.
Eventually spoke to someone on 789 who reactivated voicemail, but pin not accepted what do I do next?
Emma_C
  • 8.29K
  • 512
  • 566
Message 2 of 19
Re: Voicemail pin reset
Hi AnneKen,
Really sorry you're having an issue with your Voicemail pin, this isn't good.
So when we reset your Voicemail did you receive a text message to confirm the new pin?
If so is this the pin you used which isn't working?
Emma_C - Forum Team
AnneKen
  • 6
Message 3 of 19
Thanks, eventually, when voicemail unblocked the pin worked and I was able to reset to a new pin.
Williamwjb
Message 4 of 19
Can you please help reset my voicemail pin, thank you
Steven_L
  • 11.32K
  • 685
  • 1.15K
Message 5 of 19
Hey @Williamwjb,
Sorry to hear that your having issues with your voicemail.
Have you been able to get this resolved since your last post? If noit, I would be happy to take a further look into this for you, should you need further help.
Steven_L
Macarena
Settling in
Message 6 of 19
Hi, I’m abroad in Spain and I’m unable to access my voicemail because it’s asking for a pin. I’ve never set a pin for my voicemail so I don’t know what it is. I need to access my voicemail urgently so please send me my pin ASAP.
Alex_RM
  • 7.24K
  • 367
  • 547
Message 7 of 19
Hi Macarena,
Thanks for posting and welcome to our community 🙂
I'm sorry to hear you're having some issues with the voicemail PIN, so I can help I've sent you a private message (purple envelope, top right hand corner)
Alex_Rm
cajaguars
Message 8 of 19
Hi there,
I'm currently abroad and struggling to access my voicemail becuase it requires a pin that I've not set before. Would someone be able to help me reset it please.
Kind regards,
Craig
Tags (1)
Hayley_S
  • 3.9K
  • 129
  • 255
Message 9 of 19
Hello @cajaguars,
Welcome to the community page, thank you for reaching out to us.
Is this regarding your mobile or landline?
Many thanks,
Hayley
cajaguars
Message 10 of 19
Hey @Hayley_S,
Yes this concerns my mobile device.
Kind regards,
Craig
