Voicemail box full of callbacks not msgs!
My msg box for voicemails is filled by cold callers wanting me to put $s into OTC. However I can't simply listen to the 34 msgs and delete as when I ring 222 to listen as instead it redials somehow back to the cold caller. Is there anyway to delete all msgs?
Tags (2)
  • 4.8K
  • 695
  • 1.29K
Re: Voicemail box full of callbacks not msgs!
If you set up a Voicemail PIN. You can switch your mobile off and access your voicemail from another phone and delete from there.
Question is how are you getting these messages
All voicemails are left after missed calls. I tried blacklisting numbers but they must have multiple lines. I have asked them to stop but they implied it was not one company but multiple who all had same info. Anyway, rant over!! 😀 I will try turning voicemail off completely!! Thank you
