on 07-06-2022 11:46
I was trying to check my voicemail but it asks for a pin which I never setup. Any ways to remove the pin?
on 07-06-2022 13:52
Hi Hashraf99,
Thank you for posting in our community forums, sorry to see you are having issues with our voicemail service. If you can call voicemail, use the wrong PIN, choose to ‘Request a new PIN’ – a temporary PIN will be texted to you. Redial voicemail and use the temporary PIN in 24 hours (before it expires). Create your new PIN. If you can do these steps for us and once it has been done let us know how you get on. Please sure every step is done in order for it to work.
Thank you.
Ari - Forum Team
