Portman40
  • 6
Voicemail PIN
HI
I wish to access my voicemail from a landline, but it is asking for a PIN, which I cannot remember.  After trying several possibilities it says my voicemail is locked.
Can you reset the PIN and then can I change it to something I should remember?
Thank you
David_Bn
  • 4.95K
  • 228
  • 405
Re: Voicemail PIN
Good Afternoon Portman40,
Thanks for your post on our Community Forums and I'm sorry to see this post has not been responded to sooner.
Have you been able to have this issue resolved, or is this still on going?
If you still seek further assistance, drop a response below, and I can reset the PIN on your voicemail service for your mobile phone.
Kindest regards,
David_Bn
Portman40
  • 6
Re: Voicemail PIN
Hi David
The problem is still outstanding so please reset my PIN, thank you.
David_Bn
  • 4.95K
  • 228
  • 405
Re: Voicemail PIN
Thanks for coming back to me Portman40,
I'll need to take this to PM to locate your account and to pass data protection
Check out the purple envelope in the top right hand corner for my message
Kindest regards,
David_Bn
Portman40
  • 6
Re: Voicemail PIN
Thanks for the information via PM David.
All now settled thanks to your help.
Melissa_F
  • 2.78K
  • 160
  • 219
Moderator
Moderator
Re: Voicemail PIN
That's great 🙂
Thanks for letting the community know as others with the same issue know they can get the help they need here.
Melissa
