Brilliant, security has been passed BBQColin.
You will receive your new PIN by SMS. You will need to reset this after receiving the SMS, by calling your voicemail. The following points are guidelines for setting up a new PIN:
.Not be purely repetitive,eg.7777
.Not sequenced up or down,eg.1234,4321
.The PIN cannot be a significant part of the Mobile number
.New PIN's must be different from the previous PIN.
Kind regards Jodi.
