on 16-07-2022 13:02
I can not reply to texts and get virgin error 0 whilst I am roaming. I have done all the things recommended in similar posts such as changing spending cap, rebooting, etc etc and nothing. Can someone please assist as I urgently need to reply to the text I received.
Thanks in advance for any advice and help with this matter
on 16-07-2022 15:07
HI Amber4,
Thank you for reaching out to us here on the Community.
I am very sorry to hear you are experiencing issues when attempting to send a text whilst abroad.
Can you please confirm if roaming was activated prior to leaving the UK and if you have been able send text messages without issues previously?
Also, are you able to make calls and use data without problems?
Let us know and we will do all we can to help.
Thank you,
on 16-07-2022 20:52
Hi Nat,
No roaming was activated after I left the UK. I am receiving text and calls which i did not answer. I had no issues sending text in the uk and this was my first attempt at replying to a text whilst out of uk whilst roaming. At present I have no need to make calls or use mobile data so have not tried to do so.
on 17-07-2022 08:57
Thank you for confirming Amber.
So we are able to assist further, can you please confirm which handset you are currently using and which Network you connected to whilst abroad?
on 17-07-2022 11:14
Hi Nat,
Thanks gor getting back to me, my handset is the Samsung Galaxy a52s 5G. I have the handset set to automatically selecting the provider...but it is mainly Telstra that is connected and occasionally Vodafone.
on 17-07-2022 11:37
Thanks for confirming this @Amber4.
As you’re using an Android phone, please can you do the following: Selects Apps from your home screen > Virgin SIM toolkit > Roaming > Mode > Manual > International. Once this has been done you might need to reboot.
Let us know if this works for you or not. If not, can you advise where you are abroad at the moment?
on 17-07-2022 12:00
I have done this several times before contacting you and again now and it doesn't solve the problem.
I am in Australia
on 17-07-2022 12:21
Thank you for trying this for me again @Amber4. Please join me on private message so I can locate your account and pass account security. You can see your private messages at the top of the page, in the envelope icon.
on 17-07-2022 13:52
Thank you for joining me on private message @Amber4.
Can you advise if you are using a dual phone SIM? Also, can you confirm what you see as the message centre number is?
on 17-07-2022 14:28
Hi carly
I have answered this in our private messages isn't this the topic page?
