Virgin Mobile - call divert
Buttshill
Hi I am trying to find how I can divert my Virgin Mobile number to another mobile number wjen Virgin Mobile is not available on android 13.
Basically I cant get a VM signal at work or at my daughter's or at my sons houses. I have a VM esim and another SIM in my phone.
I have WIFI calling enabled and this works when I am at home and use Virgin broadband, but doesn't work at the office WIFI  or my kids WIFI.
Any help gratefully accepted.
1 ACCEPTED SOLUTION
Accepted Solutions
John_GS
Hi @Buttshill
We don't support Call Divert on mobile I'm afraid.
Best wishes.
John_GS
4 REPLIES 4
John_GS
Hi @Buttshill
Best wishes.
John_GS
Buttshill
Thanks for the response, is that for VM or O2 or both.
If both does the "new" O2 support WIFI calling for non Virgin WIFI, ie will I be able to use the "new" O2 (when switched) with a non Virgin WIFI?
I understand why you've asked this question, however we can only comment on Virgin Mobile systems, sorry.
At the moment we do not support call divert on our own systems, if you'd like to ask O2 the same question you can post on their own Community Forums here - https://community.o2.co.uk/ - Sorry that we can't advise anything more at this time.
John_GS
enlli
O2 Contract supports WiFi Calling, does not have to be Virgin Wifi. Used mine in the hospital on NHS WiFi.
O2 contact also allows call forwarding
