Wire-
  • 6
Message 1 of 12
Virgin Mobile Not connecting to 5g
Hi All,
Hope that you're well.
I recently got a 5g sim only contract and I'm using a Motorola Moto G 5G Plus but for some reason, I don't seem to have 5G when I'm in a 5G area.
Does anyone know how best to resolve this? Potentially it's either the device not being able to recognise the 5g bands that Virgin/Vodafone use or it's a Virgin/Vodafone network issue.
enlli
  • 7.05K
  • 1.12K
  • 1.98K
Message 2 of 12
Re: Virgin Mobile Not connecting to 5g
When you do a network search does 5G show as a network type?
Wire-
  • 6
Message 3 of 12
So, under preferred network type I have:
4g,3g and 2g.
enlli
  • 7.05K
  • 1.12K
  • 1.98K
Message 4 of 12
No 5G showing then. If you can't change it and select 5G from there can you do a manual network search and see if you can see Vodafone. If you can the SIM is running 4G.
5G should have Vodafone missing and EE visible.
Wire-
  • 6
Message 5 of 12
Yep, so I'm on Vodafone as there is no 5g in the list. I do have Virgin Mobile in the list though and I'm connected to Virgin.
enlli
  • 7.05K
  • 1.12K
  • 1.98K
Message 6 of 12
WScreenshot_20210418-194036_Call settings.jpgWell this is what you should have. I assume the phone is the single sim version and not dual as 5G will not work in slot two.
Sounds like a call to the dreaded 789 
Wire-
  • 6
Message 7 of 12
So it is the dual SIM version and I did put it in slot 2 when I got it as I was waiting for the number to be transferred over.
I've tried my partner's SIM and I get the 5g options so do Virgin need to push an update to fix it?
enlli
  • 7.05K
  • 1.12K
  • 1.98K
Message 8 of 12
For some time now firmware updates on Android are the generic manufacturer version and not Virgin's.
Wire-
  • 6
Message 9 of 12
So I did speak to someone and it seems that Virgin are only supporting Samsung's and iPhones for 5g. Would have been useful to know that before taking out the contract.
enlli
  • 7.05K
  • 1.12K
  • 1.98K
Message 10 of 12
Absolute rubbish from 789 as usual.
Virgin are selling far more than Samsung and iPhones on 5G.
Pity you have just signed up as I know of some good 5G deals out there.
