Misterguitar
Using a US Samsung S8 with Virgin
My partner is moving to the UK from the US and would like to carry on using her US bought Samsung S8 when she gets here, would a UK Virgin SIM work in it if she got it unlocked from the US network?
Many thanks
enlli
  • 8K
  • 1.25K
  • 2.28K
Re: Using a US Samsung S8 with Virgin
It will need to cover these bands for Virgin at present  (4G is LTE)
1800MHz (2G & 4G)
2100MHz (3G)
2600MHz (4G)
DJ_Shadow1966
  • 7.2K
  • 1.37K
  • 2.06K
Hello
The other problem she may have as well is that not all phones supplied in the USA have an actual SIM slot, if that is the case then it will not be possible.
Regards Mike
