Using a 4G SIM card in a 5G phone
brocoli
Hello,
I shall be replacing my mobile phone soon which has a 4G SIM card. If I buy a 5G phone can anyone confirm that if I transfer this 4G SIM card it will work without any problems on the 4G network on the new 5G phone? I realise that until I upgrade to a 5G SIM card, it won't actually operate on the 5G network.
1 ACCEPTED SOLUTION
Accepted Solutions
enlli
Yes it will work. However, you may find it works on 5G anyway. Most of the SIM cards produced recently do anyway.
1 REPLY 1
enlli
