Peppers
  • 50
Message 1 of 5
Using UK my allowance in Ireland?
Hi there
I'm off to Ireland the weekend.
Can I use my allowance there free of charge?
Tia
Lee
Alex_RM
  • 7.24K
  • 367
  • 547
Message 2 of 5
Re: Using UK my allowance in Ireland?
Hi Lee,
Thanks for posting 🙂
You can find information on roaming here
Alex_Rm
Peppers
  • 50
Message 3 of 5
Thank you for your reply, I've had a look can anyone tell me for quickness, as I go in the morning. Also do I have to turn on roaming in my Virgin Mobile account?
Alex_RM
  • 7.24K
  • 367
  • 547
Message 4 of 5
Roaming would need to be switched on first yes, it tells you how to do this via the link.
You can use your data, calls etc as you would at home.
Alex_Rm
Peppers
  • 50
Message 5 of 5
Alex, thank you so much.
It is appreciated
Cheers
Lee
