JH8
  • 5
Using Phone overseas
I have a pay as you go SIM. Can I use my phone in any country overseas? I really just want to receive calls/text messages not make them or use data.
Chris_W1
  • 4.05K
  • 181
  • 252
Re: Using Phone overseas
Hi JH8, thanks for message. You will be able to use the sim abroad if the roaming service has been activated. When are you looking ton go away as this would need to be done before you depart. We will also be able to turn of the data so no excessive data charges are gained. Chris
JH8
  • 5
Thanks for that. I tried to activate roaming but was not able to. I guess I am not doing it correctly.
DJ_Shadow1966
  • 6.84K
  • 1.31K
  • 1.89K
Hello
If you are in Europe then it roam like home, have a look at https://www.virginmedia.com/help/virgin-mobile-roam-like-home there are oother countries as well as the European ones all listed in the link. This link also has the other countries https://store.virginmedia.com/virgin-media-mobile/our-mobile-network/data-roaming-abroad.html
Regards Mike
