on 02-04-2023 12:27
I've travelled to the USA from the UK but phone isn't connecting to data. Roamong is enabled and there's a notification saying connect to tmobile but when I click it nothing happens.
Joe
Answered! Go to Answer
on 02-04-2023 15:51
Usually AT&T and TMobile work. However, since January you may have to enable VoLTE first (4G Calling) before they let you connect.
on 02-04-2023 15:51
on 02-04-2023 15:54
Thanks for the reply. Is that a setting on the phone or a phone call to virgin?
on 02-04-2023 16:07
Hi @Joeledge, thanks for your post on our Community Forums, and a very warm welcome to you!
You would need this to be set up on the handset, as well as with Virgin Mobile.
Can you confirm if you have this switched on, on the handset?
If you're struggling to locate this setting, can you confirm what handset you're using?
Kindest regards,
David_Bn
on 03-04-2023 11:28
Hi can't find a setting named this. I have a Samsung galaxy s10e. Thanks joe
on 03-04-2023 11:36
