on 31-03-2023 12:14
I'm abroad and, apparently like a number of people, I didn't think to set a pin before travelling. I can't set one now so I was wondering if I could get a temporary one set.
Phil
on 31-03-2023 12:41
Hello philmells.
Thanks for your first post and welcome to our Community.
I hope the weather is better than over here.
It is possible to reset your Voicemail pin from here.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
on 31-03-2023 14:02
Hello philmells.
Thank you for those details.
I did check the option for resetting your voicemail pin.
Unfortunately as your Network is in the process of migrating over to O2. Any chnages we make have to be put on hold for a short while. This is to enable the switch over to go ahead with out any issues.
I am sorry this was only found out once I checked your account.
Gareth_L
on 08-04-2023 10:26
on 08-04-2023 10:28
Many apologies,
Have you received confirmation of when the switch date will be?
Regards,
on 10-04-2023 15:35
on 10-04-2023 15:40
Thanks for coming back to us philmells, you should have been informed that your account was migrating to the O2 systems a few weeks ago.
Kind Regards,
Steven_L
