ashpole
  • 150
  • 18
Up to speed
Message 1 of 8
Strange PAC
Does anyone know if this looks right or a bit wrong?
Just requested PACs for my two lines on the same account. The PACs have the same VRGx code but can be differentiated by their phone numbers.
I would have thought I’d have got two different VRGx codes... 🤔
Tags (1)
enlli
  • 7.05K
  • 1.11K
  • 1.98K
Message 2 of 8
Re: Strange PAC
The VRXx code should be different for each number. If they are the same the question is which one actually applies to what number.
ashpole
  • 150
  • 18
Up to speed
Message 3 of 8
Re: Strange PAC
Exactly. I hope it’s not another VM **bleep**-up. I’ll try one line at a time and it either transfers or doesn’t. Then when I submit the second PAC it’ll likely say it’s expired/invalid - I hope!
ashpole
  • 150
  • 18
Up to speed
Message 4 of 8
Re: Strange PAC
@enlli
Fixed it: One at a time I converted the PAC to a STAC and then back again. Now each line has got its own unique PAC.
enlli
  • 7.05K
  • 1.11K
  • 1.98K
Message 5 of 8
Re: Strange PAC
@ashpole wrote:
@enlli
That's handy to know as I have no doubt someone else will end up in the same position
ashpole
  • 150
  • 18
Up to speed
Message 6 of 8
Re: Strange PAC
I'm sure. And if anyone gets confused what they have, the PAC format is VRGxxxxxx and a STAC xxxxxxVRG.
Tom_F
  • 3.06K
  • 182
  • 382
Message 7 of 8
Re: Strange PAC
Hi ashpole, thanks for your post.
It is possible to port out multiple numbers from the same account using one PAC code, though it's not often done as it could cause confusion as it appears it did here. I would always port them separately with individual codes.
Glad you got it sorted in the end anyway. If we can help with anything please let us know.
Tom
ashpole
  • 150
  • 18
Up to speed
Message 8 of 8
Re: Strange PAC
Thanks Tom, yep, all sorted.
Mike
