Janey38
  • 9
Message 1 of 17
Speed test
Hello. I've downloaded the app Open Signal and was wondering if someone could help me with the results please?
The test was done indoors 4g Virgin and I got
Download 234Kbps, Upload 1Kbps and Latency 176ms.
I thought I would be able to Google but am still confused!!!
Ashleigh_C
  • 3.74K
  • 152
  • 288
Message 2 of 17
Re: Speed test
Hi there @Janey38
Thank you so much for your post and of course we would love to help!
Can I ask what exactly you need help with?
Thank you.
Ash_C
Janey38
  • 9
Message 3 of 17
Re: Speed test
Hello Ash many thanks for your reply.
I'm just trying to find out how my phone is performing as originally I had to have a sim swap due to no 4g. This seemed to resolve but I'm again having issues.
enlli
  • 9.41K
  • 1.41K
  • 2.71K
Message 4 of 17
Re: Speed test
You are best using Speedtest by Ookia from your App Store. Open Signal is OK but you need a dedicated tester
Ashleigh_C
  • 3.74K
  • 152
  • 288
Message 5 of 17
Re: Speed test
I'm very sorry to hear this @Janey38 apologies if I've missed this but what issues are you facing?
Is this just over 4G and is the connection very slow?
Thank you.
Ash_C
Janey38
  • 9
Message 6 of 17
Re: Speed test
Hi again.  There doesn't seem to be a very high signal bar on this phone. I now have a Nokia 6.1 to hand so will try that too.
Ashleigh_C
  • 3.74K
  • 152
  • 288
Message 7 of 17
Re: Speed test
Thank you @Janey38 if you are able to try the SIM in another phone and see if this issues is also present that would be great.
Just to be clarify are you referring to your signal needed to make calls or your 4G data?
Thanks again.
Ash_C
Janey38
  • 9
Message 8 of 17
Re: Speed test
Hello again.
I've tried the sim in the nokia and only have one signal bar and no 4g at all.
Travis_M
  • 3.6K
  • 128
  • 267
Message 9 of 17
Re: Speed test
Hi @Janey38
Thanks for the reply!
Do you receive poor signal everywhere you go?
Travis_M
Janey38
  • 9
Message 10 of 17
Re: Speed test
Hello. Yes the signal isn't that good in any of the places I've been and got 4g only once or twice.
