cwatki123
Message 1 of 11
Sim won’t connect when roaming
I have an iPhone SE (2nd Gen) and when visiting the Isle of Man two weeks ago my phone wouldn’t connect to any mobile network consistently. It appeared to connect very briefly to the local network (Manx Mobile) but then would disconnect after 5-10 seconds. In this time I was unable to make calls and texts didn’t come through. My partner’s phone (Pixel 3) which is also Virgin Mobile and on the same Virgin account connected straight away upon arrival and worked the whole time we were there. My partner’s sim also worked fine in my phone.
I spoke to Virgin tech support and they took me through the troubleshooting (off and on, APN settings, reset network settings, sim in and out) and also checked my account was set up for roaming. The issue was not resolved. They ordered me a new sim which I switched to when I arrived home, and they insisted this would solve the problem.
I am now in the Isle of Man again and I have the exact same problem (my phone won’t connect, partner’s phone will). We switched sims and once again, partner’s sim works in my phone fine, but mine doesn’t work in his - so obviously the issue is my sim/account and not the iPhone. Pics attached of what I see when it’s my sim in his phone (networks all show as forbidden) and when it’s his sim in his phone (all networks available).
PLEASE someone help me! I was supposed to be working whilst here today and can’t because I can’t connect to a network.
enlli
  • 9.32K
  • 1.4K
  • 2.68K
Message 2 of 11
Re: Sim won’t connect when roaming
This sometimes works with iPhones.
Settings -> mobile data -> SIM Applications (near bottom) -> tap "Roaming"  -> tap "Select Mode"
I found "automatic" is selected by default.
Tap manual -> then choose International
You may have to restart the phone
On return set it back to National or Automatic
cwatki123
Message 3 of 11
THANK YOU!!!
This works! I’ve no idea how or why, but it works. Bizarrely I didn’t have to change this setting for my partner’s sim to work in my iPhone. Very strange.
enlli
  • 9.32K
  • 1.4K
  • 2.68K
Message 4 of 11
It seems it's random whether the automatic setting works or not.
Robert_P
  • 4.02K
  • 189
  • 370
Message 5 of 11
Hi cwatki123
Thanks for the update and glad to hear the roaming service is now working for you in the Isle Of Man.
You can find some helpful advice here regarding using your handset abroad and details on the potential charges for using your handset in the Isle of Man here once the page is open just select your contract type 🙂
Rob
Calroy
Message 6 of 11
My 5g sim card will only register on the network for a few seconds before losing signal. I've tried virgin and Vodafone networks and had settings resent but still not connecting
Ashleigh_C
  • 3.22K
  • 127
  • 255
Message 7 of 11
I'm so sorry to hear this @Calroy
Have you been able to try another handset with the SIM at all?
Does this happen in all locations or in just in particular?
Thank you
Ash_C
Calroy
Message 8 of 11
Happens in all locations but other virgin sims work in my phone
John_GS
  • 12.93K
  • 659
  • 1.2K
Message 9 of 11
Hi Calroy
Thanks for coming back to us.
I shall send you a PM to check this further as not been able to locate your account from the forum information.
Best
John_GS
twen_angst
Message 10 of 11
I was in Switzerland over the holidays, and I urgently needed to get in touch with someone, so I switched on my roaming, but the 4g didn't connect, so I couldn't get in touch online, and the sim card didn't connect either, so i couldn't even call or send a text message. However, I still paid £3.00 in roaming charges, even though it didn't actually work. Can you please sort this, as I don't think I should pay for a service I didn't actually get to use!
Thanks in advance for helping me resolve this
