doddlefrog
Sim not valid problem
Hi.I own a Nokia model 1208 type RH-105. I received a new sim card from virgin and when I placed it in my phone a message appeared saying SIM NOT VALID. I tried the unlocking code.Does not work.I viewed other posts and got a link to a form for unlock phone request and filled in that form.
If this new sim is not compatible with older phones can virgin advise what cheap phones are compatible with their new sim as this will avoid confusion and buying a phone not supported by virgins new sim?
Tags (1)
enlli
  • 7.05K
  • 1.11K
  • 1.98K
Re: Sim not valid problem
All new phones bought SIM free and Unlocked will work.
Plenty of really good basic phones out there at the moment that would replace your Nokia and not tie you in to Virgin if you change in the future
doddlefrog
I bit the bullet and bought a Nokia 105.Works no problem with new sim.Cost £19.99 from carphone warehouse.
