Signal
Kingsley1
My signal has gone in BS149TE this area is a city and it has gone from 20mb to half a megibite . Come on Virgin help me this is two weeks and all I have been told is to move to someone better like 02 mobile .
I need technical email to get help please .  
11 REPLIES 11
Can any one give me the email so I can send technical team the photos of my bad signal from 20mb to half a megibite .
Some people say it is what virgin does to make people go out and buy broadband that cost £450 pounds . I need someone in technical to look why the signal has gone ! .
Kingsley1
Why has my signal gone from 20mb down to half a megibite and after two weeks I am getting nowhere with the help virgin team .
Kingsley1
enlli
Not sure whether your phone is using EE or Vodafone for signal but EE's signal checker says there was a fault in the area.
When it comes to signal Virgin being an MNVO can do little to help as that is the responsibility of the host network
Kingsley1
I had 20 mb of signal coming to my home but on the 9th of August the engineers did some work to the mobile phone signal mask the work stayed to the 15th but since then I have had virtually zero signal. Just half a MB of signal on most times the day. I live in Bristol BS14 9TE . There are are several masks around my area owned by Vodafone. The signal mask where virgin gets its signal now comes around 7 miles away which means I and lots of others have a poor signal. Why has the signal gone down so poorly I ask people. Most people come back saying that virgin is trying to promote their broadband. This would mean that people would pay £500 more . Is it just a virgin scam or is there some truth to this. All I get when I speak to technical team is to move away to a better company which I thinks unfair when I've already set in a contract. What do you think . Is not fare is it .
Kingsley1
The signal mask was so call worked on and now I have no signal with Virgin the technical team seem not to care just saying best to move or buy broadband at the cost of 500 pounds . What is this world all about . Just look at my signal now from 20mb to half a megibite .
Zoie_P
Hi Kingsley,
Please do not multi-post as this makes it harder to help. I can see we have replied to your previous post.
Please reply to us there so we can best assist.
Zoie
enlli
The last figures you posted were for 3G you are not going to get 20Mb on that. Perhaps your 4G signal has disappeared?
Virgin do not slow you down to sell broadband as I say they have no control over such things. That's how Virtual Networks run.
If you are not happy I think the advice on changing networks is a good one, but make sure it's with one of the big 4 or you will end up on another MNVO.
Paulina_Z
Hi @Kingsley1,
Thank you for coming back to us. Sorry, I'm a little confused. Are you experiencing some Mobile issues, or issues with your broadband speeds? If so, what problems are you having?
Please let us know so we can assist correctly and have this issue resolved for you.
Thank you.
Paulina_Z
