Twiggy1965
Signal keeps dipping
I have been with Virgin for a couple of months now but my phones signal keeps dipping in and out! I have missed very important phone calls and text messages come through hours after they have been sent!. If I try and ring out it doesn't connect. This has become very frustrating as I came from EE which wasn't that bad a signal!  😔
Corey_C
  • 2.74K
  • 152
  • 221
Re: Signal keeps dipping
Thanks for your post and welcome to the Community Forums, Twiggy1965,
Apologies for the delayed response. Have you been able to get this sorted since your post?  Our online troubleshooter maybe able to help with mobile connections: https://devicesupport.virginmedia.com/
If you have a compatible handset, you can also try our wifi calling which uses your wifi connection to make calls instead of the mobile network: https://www.virginmedia.com/help/mobile/wifi-and-4g-calling
Cheers,
Corey C
