hot_sharkie
Samsung note 20 ultra
Does virgin movile have eSim ? If so how do i activate it ?
enlli
  • 7.05K
  • 1.11K
  • 1.98K
Re: Samsung note 20 ultra
Virgin do not do eSIMs at the moment and I suspect that won't change while all the movement between networks and takeovers is going on.
Also Virgin SIM cards are a rather unique beast being programmed by Proximus of Belgium but running in the UK. Whether they comply with eSIM standards, I'm not too sure.
Serena_C
  • 330
  • 15
  • 45
Hi @hot_sharkie
Welcome back to the Community Help Forums 🙂
Thank you for your post regarding eSIM cards - unfortunately we do not provide eSIMs currently. Apologies for the inconvenience,
Serena
