gabriele1076
STAC code not recognised
image.pngI moved abroad,
requested a STAC, got it, but getting a funny message when I am using it.
It says I cannot 'switch to the same number'.
I don't manage to get help from the chat.
Tags (1)
enlli
  • 9.39K
  • 1.41K
  • 2.71K
Re: STAC code not recognised
So you got a STAC code off Virgin. Where are you trying to apply it. Has to be applied to an account on a UK network other than Virgin
Martin_N
  • 8.05K
  • 339
  • 495
Hi gabriele1076,
Thank you for your post.
As enlli has advised the number would need to be applied a UK Mobile account other than ourselves.
Is that what you are trying to do?
^Martin
