bh015c1827
  • 5
Message 1 of 12
SIM card not working / replacement please
I have a virgin SIM card as part of my package.  It was not used for a number of months as I already had another contract elsewhere.  Now it is showing as no signal and emergency use only.
I'm assuming it has been deactivated through lack of use (which I assumed only happened to PAYG SIMs).  Can it please be reactivated or can another one be sent to me?
Kind Regards,
Paul
John_GS
  • 10.66K
  • 550
  • 973
Message 2 of 12
Re: SIM card not working / replacement please
Hi Paul.
My apologies for the SIM card issue. From the details checked, it's not deactive. Have you got signal since posting? If not, is the handset you're using it in unlocked?
Kind regards,
John_GS
bh015c1827
  • 5
Message 3 of 12
Hi John,
I have an unlocked (purchased SIM-free) dual SIM phone which contains a work SIM card and the Virgin SIM card.  Previously the Virgin SIM worked fine, I made a couple of calls with it and I received texts from Virgin each month regarding my allowances.  I received texts from Virgin on 23 Aug, 23 Sep, 23 Oct and then nothing since then.  Since that point the Virgin SIM has shown as Emergency calls only and I can now neither use it to make calls or to use data.
Just in case an issue with my phone, this morning I swapped the SIM slots, but again, only my work SIM works.
Kind Regards,
Paul
PS. I live in North London and should have excellent signal strength.
John_GS
  • 10.66K
  • 550
  • 973
Message 4 of 12
Thanks for coming back to me, Paul.
Have you got another phone you can try the SIM card in just to see if this works in there? That will confirm if it's the SIM or the phone
Kind regards,
John_GS
bh015c1827
  • 5
Message 5 of 12
I do not have another phone.
Kind Regards,
Paul
Corey_C
  • 4.78K
  • 243
  • 398
Message 6 of 12
Hi Paul,
I'll send you a private message to confirm we are looking at the right account and send a replacement if needed.
Cheers,
Corey C
bh015c1827
  • 5
Message 7 of 12
I spent yesterday trying to figure out if there was anything wrong with the phone or SIM myself and noticed that the APN of the Virgin SIM was variants of BASE.BE which seemed really strange as that seems to be an overseas provider.  I tried changing the network operator manually and this didn't help and entering Vrigin's APN (found on the internet) also did not help.
Ultimately I stumbled upon the app "SIM Tool Kit" which had a roaming option for the Virgin SIM.  I changed the "Mode" from automatic to manual and then back to automatic and suddenly I then had signal and the SIM now works fine.
No idea what the problem was as I've not left the country in over a year so it does not make sense for it to have been /stuck/ on a roaming network.  In any event all sorted.
Kind Regards,
Paul
Corey_C
  • 4.78K
  • 243
  • 398
Message 8 of 12
Thanks for replying Paul,
The APN is for internet configurations, are you able to check for my PM?
But it is interesting that the phone is showing as roaming? Have you been able to check under the network settings to see if it's connected to the network? You can find out how to do so for your phone here
Cheers,
Corey C
enlli
  • 8.02K
  • 1.25K
  • 2.29K
Message 9 of 12
Yep these SIM cards are programed either by BASE or Proximus of Belgium. I won't go into all the reasons except to say they do occasionally throw up problems with some phones which suddenly see themselves as being in Belgium and not the UK.
Corey_C
  • 4.78K
  • 243
  • 398
Message 10 of 12
When you get a chance, bh015c1827 check your PMs for my message, which is the purple envelope.
Cheers,
Corey C
