kjg
  • 6
Roaming not working in EU
I've travelled to Prague for the first time since being a virgin mobile customer. Roaming isn't working. I checked before leaving the UK that roaming was on (it already was) and that international calling was not barred. Trying to select a network manually doesn't work as they are all forbidden. Please help!
kjg
  • 6
Re: Roaming not working in EU
As a foot note, it's an Oppo Find X2 Pro running Android 12.
enlli
  • 9.81K
  • 1.45K
  • 2.82K
May be worth a go.
Worth Trying this
SIM TOOLKIT
For Android:
Select Apps from the Home Screen
Select SIM Toolkit Icon (some phones shows as Virgin)
Select Roaming
Select Select Mode
Select Manual
Select International-you are done, go back to Home Screen
To Switch back when in the UK:
Select Apps from screen
Select Virgin SIM Toolkit Icon
Select Roaming
Select Select Mode
Select Automatic and go back to Home Screen
kjg
  • 6
Great stuff, that's worked a treat.
I confess I did also put a call in to Virgin (over WiFi calling) and they told me how to find the tool kit, as somehow I couldn't see it before.
Solved, thanks again!
