SteveMani
Message 1 of 8
Remote management
I just got a phone and I keep getting stuck at the remote management. It says virgin media has configure the device
Emily_G
  • 4.78K
  • 207
  • 285
Message 2 of 8
Re: Remote management
Thanks for the post SteveMani and welcome to our community.
Can we please confirm what handset this is in regards to?
Thanks, Emily.
SteveMani
Message 3 of 8
An iPhone SE
first generation
Emily_G
  • 4.78K
  • 207
  • 285
Message 4 of 8
Thanks for confirming, have you inserted the SIM card into the handset?
Thanks, Emily.
enlli
  • 7.02K
  • 1.11K
  • 1.97K
Message 5 of 8
I've checked your images but as they contain IMEI information I'll leave it to the mods to approve.
However,  the network displaying MTN which I believe is South Africa.
This is a UK site. You may require http://www.virginmobile.co.za/
SteveMani
Message 6 of 8
The sim is not the problem
i keep getting the remote management notification and I’m been asked to login
SteveMani
Message 7 of 8
The phone was brought from the UK
And it says its been supervised by virgin Media UK
enlli
  • 7.02K
  • 1.11K
  • 1.97K
Message 8 of 8
I'm assuming then that you bought the phone second hand and whoever used it before had remote management installed by their IT department. Sounds a bit naughty to me.
Not sure Virgin UK will or can do anything in this case.
