jamietraynor
  • 11
Recent poor home mobile reception
We have noticed massive change in signal strength in our house.  All four of us on Virginmobile and for at least the last week (possibly 2 weeks) we have had difficulty maintaining calls. also v little in the way of mobile data (eg speed test results of < 1Mbps). something has clearly changed but I need decent signal to be able to work form home. Checked virgin website for my postcode and everything is 'OK' although it clearly isn't.  when i try in different parts of the city I get great reception so it seems specifically limited to the area near my house. has a mobile mast stopped working? i live in the Anniesland area of Glasgow. i tried WiFi calling but doesn't seem to work despite having compatible phone (Samsung S10e)
enlli
  • 7.4K
  • 1.17K
  • 2.09K
Re: Recent poor home mobile reception
No point in looking at Virgin its inaccurate to say the least.
As Virgin use EE check directly with them
https://myaccount.ee.co.uk/networkchecker/checkservice
jamietraynor
  • 11
Thanks.
I checked and EE say there is a problem.
So sohn if fix yet
Jamie
