  • 33
RSSI level
Im still trying to sort out whats wrong with my mobile signal. I have loaded a couple of apps and both show that my RSSI on 3G is -113
  • 2.51K
  • 157
  • 657
Problem sorter
Re: RSSI level
That's weak for 3G but would be OK for 4G, Was the signal better in the past or has it always been like this?
  • 33
Re: RSSI level
4G is much much better at -76. I understand that from previous posts that for speech you need a good 3g signal
  • 5.84K
  • 924
  • 1.62K
Re: RSSI level
Yes, calls fall back to 3G on Virgin.
Only people on networks that allow Voice over 4G (Volte) with suitable phones can use 4G for calls.
No doubt this will change when 3G is eventually abandoned.
