Questions regarding Visiting USA
miker0
Visiting USA soon. Roaming turned off.
Only making necessary calls (hopefully none)
Will messaging and Banking Apps still work?
Charges?
1 REPLY 1
Alex_RM
Hi miker0,
Thanks for posting 🙂
You can read up on roaming charges in the USA here
If you're using data to access apps or send messages you would be charged, if you use WiFi you won't.
You can manage roaming via your online account here
Alex_Rm
