paulmapson
Problems with wifi calling re calls
I have a Samsung A71 on Virgin and WiFi calling has been made available so turned it on
However I am having problems with people trying to ring me from other networks - get a beep beep then call cuts out. Not all the time but often which is annoying
So I turned off WiFi calling and I'm now receiving calls plus the sound is much clearer and sharper
  • So is this a common problem ? Is it related to virgin or is it likely to be the phone specific software ?
enlli
  • 7.36K
  • 1.17K
  • 2.08K
Re: Problems with wifi calling re calls
They do seem to be having problems going on other threads.
enlli
  • 7.36K
  • 1.17K
  • 2.08K
Afraid so. I left the mobile side 18 months ago. Never looked back
Chris_W1
  • 4.06K
  • 185
  • 255
Hi paulmapson
Have you ever been able to get this service to work for incoming calls/texts in the past?
Have you been able to test on a different WiFi network?
What about if you text your own number when using WiFI calling, what happens?
Chris
