on 12-09-2022 15:13
Prepared setup according to advice. No text on arrival in Greece now finds network but drops in seconds. Cannot select manually. Need access to phone for elderly mother. Any ideas?
Answered! Go to Answer
on 12-09-2022 15:26
Can't use data or make/receive calls or texts. Roaming is setup on account.
on 12-09-2022 15:18
Hi there @JReynard
Thank you so much for your post and welcome to the community forums it's great to have you here.
I'm so sorry to hear that you are facing this issue with your phone service!
Can I ask if you have been able to use data? Are you able to receive calls at all? Are you able to send and receive texts?
Is Roaming active on your My Virgin Mobile account?
Thank you.
on 12-09-2022 15:26
on 12-09-2022 15:30
Can I ask what make and model this phone is?
Thank you.
on 12-09-2022 15:35
Thanks it's Oppo A53
on 12-09-2022 15:42
Thank you @JReynard
Are you able to follow these steps:
Select Apps from the Home Screen
Select Virgin SIM Toolkit Icon
Select Roaming
Select Mode
Select Manual
Select International - you should then be done so pop back to the Home Screen.
Can you let me know how this goes?
Thanks again!
on 12-09-2022 15:56
Unfortunately still the same...
on 12-09-2022 16:12
Thank you @JReynard I'm so sorry that this has not yet worked for you.
I'm going to pop you a PM now so we can look into this a little further. Please keep an eye out for the purple envelope in the top right corner of your screen alerting you to a new message.
Thank you.
