on 01-06-2022 10:26
Hello people.i got a virgin sim a while ago and ported my number over..
ive noticed my imessage does not work.
ive gone to settings then phone and its my virgin number not the ported number.
ive tried changing and saving it.
but it does not work it retains the virgin number.
and help please
Answered! Go to Answer
on 01-06-2022 13:21
Did the WiFi calling remain on or did that revert back as well?
^Martin
on 01-06-2022 10:37
Hi Dereklad,
Thank you for your post. I'm very sorry to hear about the issue with your iPhone.
When you are saving the number are you using the +44 or 07?
^Martin
on 01-06-2022 11:07
Ive tried both it still wont save after i change it.
it just changes back to the original sim number.
on 01-06-2022 11:22
Thank you for that information. I'm unsure why that isn't saving. Can you try changed a different setting in that section and she if that is accepted?
^Martin
on 01-06-2022 12:19
I dont get what your saying..
it just wont save my number and just keeps resorting to the original sim number .
what other settings.
on 01-06-2022 12:44
For example could you turn on or off WiFi calling and see if it stays changed after you leave the page.
^Martin
on 01-06-2022 13:18
I turned on wifi calling as it was off.
tried changing the number to my number.
it just goes back to the other Number and wont change.
on 01-06-2022 13:21
Its just locked on this number and wont change to my number after i change it and press save.
on 01-06-2022 13:21
^Martin
on 01-06-2022 13:25
Wifi calling stayed on.
