Sanat129
  • 6
Message 1 of 43
Porting number is not being updated for iMessage
Hi There,
I was using lyca and last month switched to virgin keeping my old number but unfortunately I won’t able to retain my number for iMessage or iCloud. On my device the mobile number says different.
I’ve tried to reach customer support couple of times but no luck. Can you please help me with this.
enlli
  • 9.51K
  • 1.43K
  • 2.74K
Message 2 of 43
Re: Porting number is not being updated for iMessage
This solves some problems
Sign out of your Apple ID
Switch your phone off and then on again
Resign in to your Apple ID
Zach_R
  • 4.16K
  • 137
  • 288
Message 3 of 43
Hi @Sanat129,
I'm sorry to hear you're having a spot of bother with the number updating for iMessage. Have the steps that have been suggested by @enlli helped at all?
Zach - Forum Team
Sanat129
  • 6
Message 4 of 43
No it didn’t work. I’m tired of doing this. The number showing in attached screenshot is not mine. This is the temporary number which virgin media has given me and I was told it will be automatically done or you can manually change your number in phone (my number) but this is not working. I just don’t want to use this number and want to keep/ use my old number which I’m using since 2016.
enlli
  • 9.51K
  • 1.43K
  • 2.74K
Message 5 of 43
Seems a common problem not unique to Virgin
Got this from Giffgaff
https://community.giffgaff.com/d/3258193-ported-number-but-iphone-still-showing-old-number
John_GS
  • 14.4K
  • 737
  • 1.34K
Message 6 of 43
Hi Sanat129
When did you port in your number to us?
Kind regards,
John_GS
Sanat129
  • 6
Message 7 of 43
December 2021
John_GS
  • 14.4K
  • 737
  • 1.34K
Message 8 of 43
Are you able to go into the settings, then phone and then manually edit the number at the top of the screen.
Kind regards,
John_GS
Sanat129
  • 6
Message 9 of 43
I have done numerous times but issue is still persists.
John_GS
  • 14.4K
  • 737
  • 1.34K
Message 10 of 43
When you save it, does the number revert I'm guessing?
Is this the same with any calls made or just iMessage affected?
Kind regards,
John_GS
