chrispy1
  • 126
  • 5
Poor signal
I live in the Peterborough and the signal is never that strong. But over the las couple of days ( 6/7 October) has been very bad droppings from 4G to 3G to E to no signal at all.
Is there problem at the moment in this area?
enlli
  • 7.39K
  • 1.17K
  • 2.08K
Re: Poor signal
As Virgin use EE for signal this link should be of use
https://myaccount.ee.co.uk/networkchecker/checkservice
chrispy1
  • 126
  • 5
Re: Poor signal
Thanks for that. Apparently they are doing work.
