josephperrins
Poor mobile signal
The mobile signal is very weak in my home. I have an iPhone11. Is there anything I can do to improve it? I heard there was a device that some suppliers use to boost the signal.
enlli
  • 7.36K
  • 1.17K
  • 2.08K
Re: Poor mobile signal
No. There were devices supplied by some networks but both EE and Vodafone that supplied them are switching them off as they move people to WiFi calling. As you have an iPhone 11 that should be possible on Virgin if you have the latest firmware
Legal signal boosters costs are in the hundreds.
josephperrins
Thanks enlli
WiFi calling seems to drop in and out and I am never sure if it is working reliably.
