Madman10
Message 1 of 7
Poor home mobile signal
I have a very poor mobile signal in the house and it keeps dropping calls. I have a WiFi connection with 5 bars. Is it possible to use the WiFi connection to make and receive calls in the house? The mobile WiFi call system is up and running
DJ_Shadow1966
  • 7.11K
  • 1.36K
  • 2.01K
Message 2 of 7
Re: Poor home mobile signal
Hello
Which mobile do you have as currently only some phones  are supported for wifi calling ?
Have a look at https://www.virginmedia.com/help/mobile/wifi-calling
Where was the phone purchased from was it direct from VM ?
Regards Mike
Madman10
Message 3 of 7
Yes it was from VM. It is a Samsung and it is up to date with the software etc
DJ_Shadow1966
  • 7.11K
  • 1.36K
  • 2.01K
Message 4 of 7
Hello
What is the model of your Samsung ?
Regards Mike
Madman10
Message 5 of 7
A50 and it has the latest updated version
DJ_Shadow1966
  • 7.11K
  • 1.36K
  • 2.01K
Message 6 of 7
Hello
Looking at the list Samsung: Samsung S9, S9+, S10, S10+, S10e, S20, S205G, S20+5G, S20Ultra5G, Note10, Note 10+ and Note 10+5G that device isnt supported at this time.
Regards Mike
Madman10
Message 7 of 7
Thanks Mike I'm just disappointed that they uploaded the app on to a uncompatible phone.
