sidd_techgeek
Just joined
Message 1 of 7
Pixel 6 not compatible with Virgin Network
Hello Community ,
I purchased a Pixel-6 and a Virgin mobile customer.
Seems the pixel-6 is not compatible with the Virgin Network.Finding hard time to get the network when I am putting the Virgin SIM in my new mobile.
Not sure if any one facing this issue? I contacted Google Support they replied that Virgin guys have to upgrade there network , I am aware that Virgin uses 3 network.Not sure what is happening ?
Is nay one facing issue and  have any resolution for this ?
Sidd
BenMcr
  • 22.81K
  • 2.51K
  • 4.84K
Message 2 of 7
Re: Pixel 6 not compatible with Virgin Network
Virgin Mobile don't use the 3 network. Depending on your account you may connect to the EE radio network or the Vodafone radio network.
However whichever radio network you connect to the SIM is controlled directly by Virgin Mobile and should work in any unlocked phone designed to work in the UK.
sidd_techgeek
Just joined
Message 3 of 7
Thanks for your reply well Virgin media uses 3 network in Ireland.
https://en.wikipedia.org/wiki/List_of_Ireland_mobile_virtual_network_operators
Sidd
  • 14.13K
  • 1.89K
  • 4.34K
Message 4 of 7
Hi @sidd_techgeek
This forum is for Virgin Media UK and is not affiliated with VM Ireland.
If  you are based in ireland then you need to contact VM Ireland. https://www.virginmedia.ie/contact/
Dave
sidd_techgeek
Just joined
Message 5 of 7
Thanks for the update , I will move there
Badscooter
Message 6 of 7
Hi Sidd
I am a virgin Media Ireland customer and have just purchased a pixel 6 and I can't connect either.
Did you solve the problem?
Gareth_L
  • 10.8K
  • 601
  • 1.2K
Message 7 of 7
HI Badscooter
Sadly we are only able to deal with Northern Ireland customers on here
Gareth_L
