considine60
Pin voicemail
I need to access my voicemail I am in Southern Ireland I cannot remember my pin. I received text message to say my voicemail was accessed from another phone
Tags (1)
enlli
  • 9.81K
  • 1.45K
  • 2.82K
Re: Pin voicemail
The team will have to take details and send you a temporary PIN which you should change on your return.
On a side note you should always set a PiN when setting up you Mailbox.
I have recently changed to an O2 SIM. The first thing I did was set a PIN before recording my greeting.
Ashleigh_C
  • 5.25K
  • 192
  • 386
Re: Pin voicemail
Hi there @considine60
Thank you so much for your post and welcome to the forums! It's great to have you on board!
I'd be happy to look into this with you and try to get a voicemail pin sorted!
I'll send you a PM now so we can do so, please keep an eye out for the purple envelope in the top right corner of your screen alerting you to a new message.
Thanks again.
Ash_C
