itsgonewrong
Phone stuck in reboot loop. Need help to get voicemail
Hello.
I need re-set my voice mail pin ( or set up, i don't recall doing so, but I have vm) I can't use the phone at present, so can anyone say how to get that done on line so I can get my messages on another phone?
Kath_F
  • 34.75K
  • 1.34K
  • 2.81K
Re: Phone stuck in reboot loop. Need help to get voicemail
Hi itsgonewrong,
Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
Apologies to hear you're having an issue with your voicemail pin. We can certainly take a look at this for you however we will need to pass data protection with you first.
I have sent you a private message regarding this and will investigate further once I receive your reply. Just click on the little plum envelope at the top right-hand side of the page to access your inbox.
Kath_F
